Display dampened path information to see which routes are suppressed.
Change the VRF instance as required to view BGP information about a specific VRF instance. The VRF must have an RP trigger of BGP. Not all parameters are configurable on non-default VRFs.
Enable dampened routes.
- Select BGP.
- Select the Dampened Routes tab.
Dampened Routes field descriptions
Use the data in the following table to use the Dampened Routes tab.
Name |
Description |
IpAddrPrefix |
Specifies the IP address prefix in the NLRI field. This variable is an IP address that contains the prefix with a length specified by IpAddrPrefixLen. Bits beyond the length specified by IpAddrPrefixLen are set to zero. |
IpAddrPrefixLen |
Specifies the length, in bits, of the IP address prefix in the NLRI field. |
Peer |
Specifies the IP address of the peer from which the router learns the path information. |
FlapPenalty |
Specifies the penalty based on number of route flaps. |
FlapCount |
Specifies the number of times a route flapped (went down and up) since the last time the penalty was reset to zero. |
RouteDampened |
Indicates whether this route is suppressed or announced. |
ReuseTime |
Specifies the system-configured time for route reuse. |
