Perform this procedure to display the data in a specific file on Fabric IPsec Gateway Virtual Machine (VM).
enable
virtual-service WORD<1-128> console
Type CTRL+Y to exit the console.
more WORD <1-255>
Switch:1> enable Switch:1# virtual-service figw console Connected to domain figw Escape character is ^Y <cr> FIGW> more coupled.cfg set global ipsec-tunnel-src-vlan 125 set global ipsec-tunnel-src-ip 192.0.2.10/24 set global lan-intf-vlan 30 set global lan-intf-ip 192.0.2.20/24 set global lan-intf-gw-ip 192.0.2.25 set global fe-tunnel-src-ip 192.0.2.45 set global wan-intf-gw-ip 192.0.2.11 set global mtu 1950 set ipsec 1 auth-key ****** set ipsec 1 fe-tunnel-dest-ip 192.0.2.50 set ipsec 1 encryption-key-length 128 set ipsec 1 admin-state enable
