The following table defines parameters for the ssh key-exchange-method command.
| Variable | Value |
[diffie-hellman-group1-sha1][diffie-hellman-group14-sha1][diffie-hellman-group-exchange-sha256] Note:
Exception: diffie-hellman-group1-sha1 is only supported on VSP 8600 Series. Exception: diffie-hellman-group-exchange-sha256 is not supported on VSP 8600 Series. |
Configures the key-exchange method. Select a key-exchange method from
one of the following:
