Perform this task to run the ls command for the VM configs directory from the VOSS CLI.
enable
configure terminal
virtual-service WORD<1-128> exec-command WORD<1-256>
From VOSS, list the contents of the home/rwa/configs directory in the Fabric IPsec Gateway VM.
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#virtual-service figw exec-command "ls /home/rwa/configs" config.cfg figw_cli.log shadov.txt
