Configure an IPv6 IS-IS accept policy to apply to a specific advertising Backbone Edge Bridge (BEB). Specify the SPBM nickname and the IS-IS accept policy name to allow you to apply the IPv6 IS-IS accept policy.
The system uses the default global filter unless a filter for a specific advertising BEB exists, in which case the system applies a more specific filter.
If the route policy changes, you must re-apply the IPv6 IS-IS accept policy, unless it was the last sequence in the configuration.
                    Enable IS-IS globally.
                    Ensure the manual area exists.
                    You must configure a route-map.
                    Change the VRF instance as required to configure an IPv6 IS-IS accept policy for a particular advertising BEB on a specific VRF instance. Not all parameters are configurable on non-default VRFs.
- Click IS-IS.
- Click the Accept Nick Name tab.
- Click Insert.
- In the AdvertisingRtr field, specify the SPBM nickname.
- Select Enable to apply the filter.
- Optional: In the PolicyName field, specify the route-map name.
- Click Insert.
Accept Nick Name Field Descriptions
Use the data in the following table to configure the Accept Nick Name tab.
| Name | Description |
| AdvertisingRtr | Specifies the SPBM nickname to apply the IS-IS accept policy to routes for a specific advertising BEB. The system first uses the default filter, but if a more specific filter for a specific advertising BEB is present the device applies the specific filter. |
| Enable | Enables the SPBM nickname advertising router entry. The default is disabled. |
| PolicyName | Specifies a route policy. |
