View the status of OSPFv3 route redistribution to verify the current configuration. You can redistribute directly connected routes and IPv6 static routes into OSPFv3.
Switch:1#show ipv6 ospf redistribute
                        OSPFv3 Redistribute List - GlobalRouter
SOURCE  MET    MTYPE      ENABLE RPOLICY
Static  0      external   TRUE
Use the data in the following table to use the show ipv6 ospf redistribute command.
| Variable | Value |
| vrf WORD<1-16> | Specifies the VRF name. |
| vrfids WORD<0-512> | Specifies VRF IDs. |
