View information about Ethernet errors to display information about the types of Ethernet errors sent and received by a specific MLT or all MLTs.
Important
The IMAC columns refer to internal MAC address errors.
Switch:1#show mlt error main 40
Mlt Ethernet Error
MLT ALIGN FCS IMAC IMAC CARRIER FRAMES SQETEST DEFER
ID ERROR ERROR TRNSMIT RECEIVE SENSE TOOLONG ERROR TRNSMSS
40 0 0 0 0 0 0 0 0
Variable definitions
Use the data in the following table to use the show mlt error main command.
Variable |
Value |
<1-512> |
Specifies the MLT ID. The value ranges from 1–512. |
