Feature |
Product |
Release introduced |
TLS server for secure HTTPS Note:
VOSS Releases 6.0 and 6.0.1 do not support this feature. |
5420 Series |
VOSS 8.4 |
5520 Series |
VOSS 8.2.5 |
VSP 4450 Series |
VOSS 5.1.2 |
VSP 4900 Series |
VOSS 8.1 |
VSP 7200 Series |
VOSS 5.1.2 |
VSP 7400 Series |
VOSS 8.0 |
VSP 8200 Series |
VOSS 5.1.2 |
VSP 8400 Series |
VOSS 5.1.2 |
VSP 8600 Series |
VSP 8600 6.1 |
XA1400 Series |
VOSS 8.0.50 |
This feature enhances communications security by implementing Mocana NanoSSL to secure HTTPS server using Transport Layer Security (TLS) cryptographic protocol.
The following are the key properties of Secure web server with TLS:
This feature can be implemented on a maximum of only 10 concurrent client connections.
The switch supports version TLS 1.2 and above by default. You can explicitly configure TLS 1.0 and TLS 1.1 version support using CLI or EDM.
This feature replaces SSL 3.0 with TLS. SSL 3.0 is not supported.
TLS server does not support RC4, DES, TDES, and MD5 based cipher suites.
The minimum password length for the web server is 8 characters, by default. You can change this using CLI or EDM.
For information about the certificate order priority when the Transport Layer Security (TLS) server and switch connect, see Certificate Order Priority.
