Perform this procedure to display information about an installed Solid State Drive (SSD) on a switch.
- Select Chassis.
- Select the SSD tab.
SSD Field Descriptions
Use the data in the following table to use the SSD tab.
| Name | Description |
ProductName |
Specifies Solid State Drive (SSD) product name. |
| VendorName |
Specifies the SSD vendor. |
| ManufactureDate |
Specifies the date on which the SSD was manufactured. |
| SerialNum |
Specifies the SSD serial number. |
| PartNum |
Specifies the SSD part number. |
| DeviceVersion |
Specifies the version of the SSD. |
| TotalSize |
Specifies the total memory size of the SSD. |
