This procedure only applies to XA1400 Series.Perform this procedure to configure a specific source IP address for the IPsec tunnel when you deploy the XA1400 Series in an environment that requires more than one provider connection with IPsec.
Configure a VLAN, brouter, or CLIP IP address for the IPsec tunnel to use; this address must be in the same VRF as the tunnel.
Disable IPsec on the logical interface.
The static source IP address for the IPsec tunnel cannot be the same as the global or dynamically configured source IP address.
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#logical-intf isis 3 Switch:1(config-isis-3-198.51.100.1)#ipsec tunnel-source-address type static 20.20.20.20 Switch:1(config-isis-3-198.51.100.1)#ipsec
The following table defines parameters for the ipsec tunnel-source-address type static command.
| Variable | Value |
| {A.B.C.D} |
Specifies the manually configured source IP address for the IPsec tunnel. The source IP address must be on the same VRF as the source IP address for the IP tunnel. |
