Use the following procedure to link an IPsec policy to an interface, and configure a policy direction. By default, the direction is both.
You cannot delete or modify an IPsec policy if the policy links to a port or VLAN interface. If you need to modify the policy, first unlink the policy from the port or VLAN interface.
You must enable IPsec on the interface first, and then you link the IPsec policy to the interface.
Interface Policy field descriptions
Use the data in the following table to use the Interface Policy tab.
Name |
Description |
Name |
Specifies the IPsec policy name. |
IfIndex |
Links a policy to either a port, VLAN, loopback, or management interface. |
IfEnabled |
Shows if the IPsec is enabled on the interface and if the administrative state of the policy is enabled. |
IfDirection |
Specifies the direction you want to protect with IPsec:
The default is bothDirections. |
