Use this procedure to protect additional host names with a single certificate.
The switch supports 100 subject alternative names.
    enable
    configure terminal
  2. Configure a subject alternative name for the entity:
    certificate subject-alternative-name <dns | e-mail | ip> WORD<1-255>
  3. View the subject alternative names configured on the switch:
    show certificate subject-alternative-name
Configure a subject alternative name for an email address and an IP address.
Switch:1>enable
Switch:1#configure terminal
Enter configuration commands, one per line.  End with CNTL/Z.
Switch:1(config)#certificate subject-alternative-name e-mail name@company.com
Switch:1(config)#certificate subject-alternative-name ip 192.0.2.22
View the configuration.
Switch:1>show certificate subject-alternative-name
                                   SAN Table
TYPE     NAME
ip       192.0.2.22
The following table defines parameters for the certificate subject-alternative-name command.
Variable Value
<dns | e-mail | ip> Specifies the type of subject alternative name to add.
WORD<1-255> Specifies the alternative name to add to the subject alternative name table.
