Use this procedure to set the IS-IS external metric-type using the global redistribute command for the following cases redistributing routes from other protocols into IS-IS.
You must configure the required SPBM and IS-IS infrastructure.
You must log on to the IS-IS router configuration mode in the CLI.
Set metric type for IS-IS routes using global redistribute command:
Switch:1> enable Switch:1# configure terminal Switch:1(config)# router isis Switch:1(config-isis)# redistribute direct metric-type internal Switch:1(config-isis)# redistribute direct enable
Variable definitions
The following table defines parameters for the redistribute direct metric-type command.
Variable |
Value |
metric-type {internal|external} |
Specifies the IS-IS metric type.
