The following table and sections list the RFCs that the switch supports.
Request for comment |
Description |
draft-grant-tacacs-02.txt |
TACACS+ Protocol |
RFC 768 |
UDP Protocol |
RFC 783 |
Trivial File Transfer Protocol (TFTP) |
RFC 791 |
Internet Protocol (IP) |
RFC 792 |
Internet Control Message Protocol (ICMP) |
RFC 793 |
Transmission Control Protocol (TCP) |
RFC 815 |
IP Datagram Reassembly Algorithm |
RFC 826 |
Address Resolution Protocol (ARP) |
RFC 854 |
Telnet protocol |
RFC 894 |
A standard for the Transmission of IP Datagrams over Ethernet Networks |
RFC 896 |
Congestion control in IP/TCP internetworks |
RFC 906 |
Bootstrap loading using TFTP |
RFC 950 |
Internet Standard Subnetting Procedure |
RFC 951 |
BootP |
RFC 959, RFC 1350, and RFC 2428 |
FTP and TFTP client and server |
RFC 1027 |
Using ARP to implement transparent subnet gateways/Nortel Subnet based VLAN |
RFC 1042 |
Encapsulating the Internet Protocol (IP) datagrams and Address Resolution Protocol (ARP) Note:
Applicable for 802.3 networks only |
RFC 1058 |
RIPv1 Protocol |
RFC 1112 |
Host Extensions for IP Multicasting (IGMPv1) |
RFC 1122 |
Requirements for Internet Hosts |
RFC 1195 |
Use of OSI IS-IS for Routing in TCP/IP and Dual Environments |
RFC 1253 |
OSPF MIB |
RFC 1256 |
ICMP Router Discovery |
RFC 1258 Note:
Exception: rlogin is only supported on VSP 8600 Series. |
IPv6 Rlogin server |
RFC 1305 |
Network Time Protocol v3 Specification, Implementation and Analysis |
RFC 1323 |
TCP Timestamp (The switch is only compliant if the TCP timestamp is enabled.) |
RFC 1340 |
Assigned Numbers |
RFC 1519 |
Classless Inter-Domain Routing (CIDR): an Address Assignment and Aggregation Strategy |
RFC 1541 |
Dynamic Host Configuration Protocol |
RFC 1542 |
Clarifications and Extensions for the Bootstrap Protocol |
RFC 1587 |
The OSPF NSSA Option |
RFC 1591 |
DNS Client |
RFC 1723 |
RIP v2 — Carrying Additional Information |
RFC 1812 |
Router requirements |
RFC 1866 |
HyperText Markup Language version 2 (HTMLv2) protocol |
RFC 1981 |
Path MTU discovery |
RFC 2068 |
Hypertext Transfer Protocol |
RFC 2080 |
RIP |
RFC 2131 |
Dynamic Host Control Protocol (DHCP) |
RFC 2132 |
DHCP Options and BOOTP Vendor Extensions |
RFC 2138 |
RADIUS Authentication |
RFC 2139 |
RADIUS Accounting |
RFC 2178 |
OSPF MD5 cryptographic authentication / OSPFv2 |
RFC 2233 |
The Interfaces Group MIB using SMIv2 |
RFC 2236 |
IGMPv2 Snooping |
RFC 2358 |
Definitions of Managed Objects for the Ethernet-like Interface Types |
RFC 2284 |
PPP Extensible Authentication Protocol |
RFC 2328 |
OSPFv2 |
RFC 2338 |
VRRP: Virtual Redundancy Router Protocol |
RFC 2362 |
PIM-SM |
RFC 2407 |
IP Security Domain Interpretation of Internet Security Association and Key Management Protocol (ISAKMP) |
RFC 2408 |
Internet Security Associations and Key Management Protocol (ISAKMP) |
RFC 2453 |
RIPv2 Protocol |
RFC 2460 |
IPv6 base stack |
RFC 2462 |
IPv6 Stateless Address Autoconfiguration |
RFC 2463 |
Internet Control Message Protocol (ICMPv6) for the Internet Protocol Version 6 (IPv6) Specification |
RFC 2464 |
Transmission of IPv6 packets over Ethernet networks |
RFC 2474 |
Definition of the Differentiated Services Field (DS Field) in the IPv4 and IPv6 Headers |
RFC 2475 |
An Architecture for Differentiated Services |
RFC 2545 |
Use of BGP-4 multi-protocol extensions for IPv6 inter-domain routing |
RFC 2548 |
Microsoft vendor specific RADIUS attributes |
RFC 2579 |
Textual Conventions for SMI v2 |
RFC 2580 |
Conformance Statements for SMI v2 |
RFC 2616 |
Hypertext Transfer Protocol 1.1 |
RFC 2710 |
Multicast Listener Discovery (MLD) for IPv6 |
RFC 2716 |
PPP EAP Transport Level Security (TLS) Authentication Protocol |
RFC 2737 |
Entity MIB (Version 2) |
RFC 2819 |
RMON |
RFC 2865 |
RADIUS |
RFC 2874 |
DNS Extensions for IPv6 |
RFC 2918 |
Route Refresh Capability for BGP-4 |
RFC 2992 |
Analysis of an Equal-Cost Multi-Path Algorithm |
RFC 3046 |
DHCP Option 82 |
RFC 3162 |
IPv6 RADIUS client |
RFC 3246 |
An Expedited Forwarding PHB (Per-Hop Behavior) |
RFC 3315 |
IPv6 DHCP Relay |
RFC 3376 |
IGMPv3 |
RFC 3411 and RFC 2418 |
SNMP over IPv6 networks |
RFC 3417 |
Transport Mappings for SNMP |
RFC 3484 |
Default Address Selection for IPv6 |
RFC 3513 |
Internet Protocol Version 6 (IPv6) Addressing Architecture |
RFC 3569 |
An overview of Source-Specific Multicast (SSM) |
RFC 3579 |
RADIUS Support For Extensible Authentication Protocol (EAP) |
RFC 3580 |
IEEE 802.1X Remote Authentication Dial In User Service |
RFC 3587 |
IPv6 Global Unicast Address Format |
RFC 3596 |
RFC 3621 |
Power Ethernet MIB |
RFC 3748 |
RFC 3810 |
Multicast Listener Discovery Version 2 (MLDv2) for IPv6 |
RFC 3825 |
Dynamic Host Configuration Protocol Option for Coordinate-based Location Configuration Information |
RFC 3879 |
Deprecating Site Local Addresses |
RFC 3986 |
Uniform Resource Identifiers (URI) |
RFC 4007 |
IPv6 Scoped Address Architecture |
RFC 4022 |
MIB for TCP |
RFC 4113 |
MIB for UDP |
RFC 4133 |
Entity MIB (version 3) |
RFC 4193 |
Unique Local IPv6 Unicast Address |
RFC 4213 |
IPv6 configured tunnel |
RFC 4250–RFC 4256 |
SSH server and client support |
RFC 4291 |
IPv6 Addressing Architecture |
RFC 4293 |
MIB for IP |
RFC 4301 |
Security Architecture for IPv6 |
RFC 4302 |
IP Authentication Header (AH) |
RFC 4303 |
IP Encapsulated Security Payload (ESP) |
RFC 4305 |
Cryptographic algorithm implementation requirements for ESP and AH |
RFC 4308 |
Cryptographic suites for Internet Protocol Security (IPsec) |
RFC 4443 |
ICMP for IPv6 |
RFC 4541 |
Internet Group Management Protocol (IGMP) and Multicast Listener Discovery (MLD) Snooping |
RFC 4552 |
OSPFv3 Authentication and confidentiality for OSPFv3 |
RFC 4601 |
Protocol Independent Multicast - Sparse Mode (PIM-SM) |
RFC 4604 |
Internet Group Management Protocol Version 3 (IGMPv3) and Multicast Listener Discovery Protocol Version 2 (MLDv2) for Source-Specific Multicast |
RFC 4607 |
RFC 4649 |
Dynamic Host Configuration Protocol for IPv6 (DHCPv6) Relay Agent Remote-ID Option |
RFC 4675 |
Egress VLAN |
RFC 4760 |
Multiprotocol Extensions for BGP-4 |
RFC 4835 |
Cryptographic algorithm implementation for ESP and AH |
RFC 4861 |
IPv6 Neighbor discovery |
RFC 4862 |
IPv6 stateless address autoconfiguration |
RFC 4893 |
BGP Support for Four-octet AS Number Space |
RFC 5095 |
Deprecation of Type 0 Routing headers in IPv6 |
RFC 5176 |
Dynamic Authorization Extensions to Remote Authentication Dial In User Service (RADIUS) |
RFC 5187 |
OSPFv3 Graceful Restart (helper-mode only) |
RFC 5242 |
The Syslog Protocol |
RFC 5321 |
Simple Mail Transfer Protocol |
RFC 5340 |
OSPF for IPv6 |
RFC 5746 |
Secure SSL Renegotatiation |
RFC 5798 |
Virtual Router Redundancy Protocol (VRRP) Version 3 for IPv4 and IPv6 |
RFC 5905 |
Network Time Protocol Version 4: Protocol and Algorithms Specification |
RFC 5997 |
Use of Status-Server Packets in the Remote Authentication Dial In User Service (RADIUS) Protocol |
RFC 6105 |
IPv6 Router Advertisement Guard |
RFC 6329 |
IS-IS Extensions supporting Shortest Path Bridging |
RFC 7047 |
The Open vSwitch Database Management Protocol |
RFC 7348 |
Virtual Extensible LAN (VXLAN) |
RFC 7610 |
DHCPv6 Shield |
