Perform this procedure to activate or deactivate Energy Saver on the switch at any time. Energy Saver is deactivated by default.
Activating Energy Saver reduces the port speed to the minimum value supported by the switch and enables PoE power saving, even if PoE is globally disabled. Deactivating Energy Saver restores the previous configuration.
Before you can change any previously saved Energy Saver settings, you must disable Energy Saver globally.
Switch:1 enable
Activate Energy Saver:
Switch:1# energy-saver activate
Deactivate Energy Saver:
Switch:1# energy-saver deactivate
The following table defines parameters for the energy-saver command.
Variable |
Value |
activate |
Activates Energy Saver manually. |
deactivate |
Deactivates Energy Saver manually. |
