Displaying foreign sources
Use the following procedure to display the foreign sources learned from MSDP or statically configured at the Controller.
- Click SPB-PIM-GW.
- Click the Controller-Foreign-Source tab.
Controller-Foreign-Source field descriptions
Use the data in the following table to use the Controller-Foreign-Source tab.
| Name | Description |
| SourceAddress | Specifies the source IP address from a foreign multicast domain. |
| GroupAddress | Specifies the multicast group IP address associated with the foreign source. |
| GatewaySysId | Displays the system ID of the node selected as the Gateway for this foreign source. GatewaySysId field will have a valid value if the Gateway is assigned to a source. If the Gateway is not assigned to a source the value is 0. |
| GatewayHostName | Displays the host name of the node selected as the Gateway for this foreign source. GatewayHostName field will have valid values if the Gateway is assigned to a source. If the Gateway is not assigned to a source the value is NULL. |
| Type | Displays the owner type for this source. |
| Owner | Displays the IP address of the MSDP peer if the foreign source is MSDP. |
