Configure Digital Diagnostic Monitoring to get information concerning the status of the transmitted and received signals to allow better fault isolation and error detection.
When you enable DDM, you see the internal performance condition (temperature, voltage, bias, Tx power and Rx power) of the pluggable transceiver. The default is disabled.
For information about how to reset a transceiver for troubleshooting purposes, see Reset a QSFP+ or QSFP28 Transceiver.
Configure the interval to 10 seconds and enable DDM.Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#pluggable-optical-module ddm-monitor-interval 10 Switch:1(config)#pluggable-optical-module ddm-monitor
Use the data in the following table to use the pluggable-optical-module command
| Variable | Value |
ddm-alarm-portdown |
When enabled, the port goes down when any alarm occurs. The default is disabled. |
ddm-monitor |
Enables DDM. When enabled, you see the internal performance condition (temperature, voltage, bias, Tx power and Rx power) of the pluggable transceiver. The default is disabled. |
ddm-monitor-interval <5-60> |
Configures the DDM monitor interval. If an alarm occurs, the log message is received within the specific interval. The default value is 5 seconds. |
ddm-traps-send |
Enables or disables the sending of trap messages. When enabled, the trap message is sent to the device manager any time the alarm occurs. The default is enabled. |
