View RMON1 and RMON2 information on the switch. You can view information about RMON1 alarms, events, history, logs, and statistics. You can also view RMON2 information about application host statistics, control tables, network host statistics, and protocol distribution statistics.
View RMON event, log, and statistics information:
Switch:1(config)#show rmon event
Rmon Event
INDEX DESCRIPTION TYPE COMMUNITY OWNER LAST_TIME_SENT
60534 Rising Event log-and-trap public 192.0.2.155 none
60535 Falling Event log-and-trap public 192.0.2.155 8 day(s), 19:14:32
Switch:1(config)#show rmon log
Rmon Log
INDEX TIME DESCRIPTION
60535. 1 8 day(s), 19:14:45 1.3.6.1.4.1.2272.1.19.14.0 (absValue = 0, Falling
Threshold = 2, interval = 10)[alarmIndex.1][trap]
"Falling Event"
60535. 2 8 day(s), 19:14:45 1.3.6.1.4.1.2272.1.19.14.0 (absValue = 0, Falling
Threshold = 1, interval = 10)[alarmIndex.2][trap]
"Falling Event"
Switch:1(config)#show rmon stats
Rmon Ether Stats
INDEX PORT OWNER
1 1/10 monitor
The following table defines parameters for the show rmon command.
Variable |
Value |
address-map |
Displays the RMON2 address map. This RMON2 parameter expands RMON capacity to display information on network, transport, and application layers. |
alarm |
Displays the RMON1 alarm table. |
application-host-stats WORD<1–64> Note:
Exception: rlogin application is only supported on VSP 8600 Series. However, RMON2 counts application packets received on any platform on which the application is not enabled or supported, before dropping them. |
Displays RMON2 application host statistics from one of the following protocols: TCP, UDP, FTP, Telnet HTTP, rlogin, SSHv2, TFTP, SNMP, HTTPS. This RMON2 parameter expands RMON capacity to display network, transport, and application layers. |
ctl-table |
Displays the RMON2 control tables. This RMON2 parameter expands RMON capacity to display network, transport, and application layers. |
event |
Displays the RMON1 event table. |
history |
Displays the RMON1 history table. This RMON1 parameter displays and is limited to link layer information, including as MAC information. |
log |
Displays the RMON1 log table. |
network-host-stats |
Displays RMON2 network-host statistics. This RMON2 parameter expands RMON capacity to display network, transport, and application layers. |
protocol-dist-stats |
Displays RMON2 protocol distribution statistics. This RMON2 parameter expands RMON capacity to display network, transport, and application layers. |
stats |
Displays the RMON1 statistics table. This RMON1 parameter displays and is limited to link layer information, including as MAC information. |
