View information about the BGP configuration.
BGP Configuration - VRF vrf1
BGP version - 4
local-as - 22610
Identifier - 27.82.217.1
BGP on/off - ON
as-4-byte - disable
as-dot - disable
aggregation - enable
always-cmp-med - disable
auto-peer-restart - enable
auto-summary - enable
comp-bestpath-med-confed - disable
default-local-preference - 100
default-metric - -1
deterministic-med - disable
flap-dampening - disable
debug-screen - Off
global-debug - none
ibgp-report-import-rt - enable
ignore-illegal-rtrid - enable
max-equalcost-routes - 1
no-med-path-is-worst - enable
route-refresh - disable
orig-def-route - disable
orig-v6-def-route - disable
quick-start - disable
synchronization - enable
--More-- (q = quit)
The following table defines parameters for the show ip bgp conf command.
Variable |
Value |
vrf WORD<1–16> |
Specifies a VRF instance by name (the string length ranges from 1–16 characters). |
vrfids WORD<0–512> |
Specifies a range of VRFs by ID number (the ID ranges from 0–512). |
