You can use this interface type for OOB management network routing, as an alternative to in-band network routing management.
The OOB Segmented Management Instance is not supported on VSP 4450 Series, VSP 8600 Series. or XA1400 Series.
The following list defines the abilities of this interface type:
You can assign a management IP address bound to the Out-of-Band (OOB) interface.
You can associate only one OOB interface with an OOB Management Instance IP address.
The Dynamic Host Configuration Protocol (DHCP) Client can request an IPv4 address for the OOB Management Instance interface.
You must configure a default or static route to reach the next-hop gateway; no routing protocol information is used to access off-link networks.
You can configure only Layer 3 networking parameters in the Management Instance Configuration mode (mgmt OOB) in CLI.
You can configure only Layer 1 and Layer 2 networking parameters in the mgmtEthernet Interface Configuration mode (interface mgmtEthernet mgmt) in CLI.
