This procedure only applies to the VSP 7400 Series.
Configure IP Shortcuts on the boundary nodes.
Perform this procedure to configure Multi-area SPB IPv6 unicast redistribution on the switch.
Configuring Multi-area SPB IPv6 unicast redistribution for home to remote direction:
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#router isis
Switch:1(config-isis)#multi-area ipv6 redistribute unicast home-to-remote
Switch:1(config-isis)#multi-area ipv6 redistribute unicast home-to-remote route-map test
Switch:1(config-isis)#multi-area ipv6 redistribute unicast home-to-remote enable
Switch:1(config-isis)#show isis multi-area ipv6 redistribute home-to-remote
ISIS Multiarea Redistribute List for ipv6 unicast - GlobalRouter
DIRECTION ENABLE RPOLICY
home-to-remote TRUE test
Switch:1(config-isis)#isis multi-area ipv6 apply redistribute unicast home-to-remote
The following table defines parameters for the multi-area ipv6 redistribute unicast and the isis multi-area ipv6 apply redistribute unicast commands.
| Variable | Value |
| enable |
Enables Multi-area SPB IPv6 unicast redistribution on the switch. |
| home-to-remote |
Specifies the IPv6 unicast redistribution configuration for home to remote direction. |
| remote-to-home |
Specifies the IPv6 unicast redistribution configuration for remote to home direction. |
| route-map WORD<1-64> |
Specifies the name of the route policy. |
| vrf WORD<1-16> |
Specifies the IPv6 unicast redistribution configuration for a specific VRF instance. |
