View information about the neighbors on the virtual link to the OSPFv3 backbone.
- In the navigation tree, expand the following folders:
- Click OSPFv3.
- Click the Virtual Neighbors tab.
Virtual Neighbors field descriptions
Use the data in the following table to use the Virtual Neighbors tab.
| Name | Description |
| Area | Shows the ID for the transit area. |
| RtrId | Shows the ID for the neighboring router in the autonomous system. |
| LocalIfIndex | Shows the local interface ID for the virtual link over which the switch can reach the neighbor. |
| AddressType | Shows the type of address as one of the following:
 ipv4z and ipv6z indicate a scope zone. |
| Address | Shows the IPv6 address that this virtual neighbor advertises. This value must be a global scope address. |
| Options | Shows a bit mask that corresponds to the OSPF options field of the neighbor. |
| State | Shows the state of the virtual neighbor relationship. The value can be one of the following:
