Enabling the Controller
Enable the Controller globally.
- Click SPBM.
- In the row for the SPBM, double click the McastSpbPimGwControllerEnable field, and then select true.
- Click Apply.
SPBM field descriptions
Use the data in the following table to use the SPBM tab.
Name |
Description |
McastSpbPimGwControllerEnable |
Enables or disables the ISIS multicast SPM-PIM Gateway Controller node. |
McastSpbPimGWGatewayEnable |
Enables or disables the ISIS multicast SPM-PIM Gateway node. |
