This procedure does not apply to VSP 8600 Series or XA1400 Series.
Use this task to view IPv6 address statistics for a Segmented Management Instance.
- Select Mgmt Instance.
- Select Stats.
- Select the IPv6 tab.
- To clear IP statistics, select Clear Stats.
- To clear IP counters, select Clear Counters.
IPv6 Field Descriptions
Use the data in the following table to use the IPv6 tab.
| Name | Description |
| InReceives | Shows the inbound packet statistics. |
| InHdrErrors | Shows the inbound packets with header errors statistics. |
| InAddrErrors | Shows the inbound packets with address errors statistics. |
| InUnknownProtos | Shows the inbound packets with unknown protocols statistics. |
| InDiscards | Shows the inbound packets discarded statistics. |
| InDelivers | Shows the inbound packets delivered statistics. |
| InTooBigErrors | Shows the inboud packets too big errors statistics. |
| InNoRoutes | Shows the inbound packets with no routes statistics. |
| InTruncatedPkts | Shows the inbound packets truncated statistics. |
| InMcastPkts | Shows the inbound multicast packets statistics. |
| InOctets | Shows the inbound octets statistics. |
| InMcastOctets | Shows the inbound multicast octets statistics. |
| InBcastOctets | Shows the inbound broadcast octets statistics |
| InNoECTPkts | Shows the inbound packets with no Explicit Congestion Notification (ECN) statistics. |
| InECT1Pkts | Shows the inbound packets with ECT(1) statistics. |
| InECT0Pkts | Shows the inbound packets with ECT(0) statistics. |
| InCEPkts | Shows the inbound packets with Congestion Ecountered (CE) statistics. |
| OutRequests | Shows the outbound packet requests statistics. |
| OutDiscards | Shows the outbound packets discarded statistics. |
| OutNoRoutes | Shows the outbound packets with no routes statistics. |
| OutForwDatagrams | Shows the forwarded datagram packets statistics. |
| OutMcastPkts | Shows the outbound multicast packets statistics. |
| OutOctets | Shows the outbound octets statistics. |
| OutMcastOctets | Shows the outbound multicast octets statistics. |
| OutBcastOctets | Shows the outpound broadcast octets statistics. |
| ReasmTimeout | Shows the packet reassembly timeouts statistics. |
| ReasmReqds | Shows the packet reassembly requests statistics. |
| ReasmOKs | Shows the successfully reassembled packets statistics. |
| ReasmFails | Shows the failed reassembled packets statistics. |
| FragOKs | Shows the successfully fragmented packets statistics. |
| FragFails | Shows the failed fragmented packets statistics. |
| FragCreates | Shows the fragments created statistics. |
