A virtual service provides the ability to support additional applications or services and simultaneously support the regular switching functionality. Each virtual service provides an Open Virtual Appliance (OVA) image, which is installed on Extreme Integrated Application Hosting (IAH) through Extreme Management Center or ExtremeCloud IQ - Site Engine.
Use FTP or SFTP to transfer the OVA image to the /var/lib/insight/packages/ directory on the switch.
The Fabric IPsec Gateway image includes no integrity check. Use SCP to copy the file to the switch and confirm the file size before installation.
Perform this procedure to install a package file to a specific location indicated by a virtual service name. This procedure also verifies if the package is in OVA format, and if a certificate is provided in the package.
The following table defines parameters for the virtual-service command.
Variable |
Value |
WORD<1-128> |
Specifies the virtual service name. |
install |
Installs the virtual service package. |
package WORD<1-512> |
Specifies the package name and path. |
