Perform this procedure to view basic manufacturing information and characteristics, and the current configuration.
This command displays information for DDI transceivers.
Transceiver support differs across hardware platforms. For information about supported parts, see Extreme Optics website.
Switch:1#show pluggable-optical-modules config
                 Pluggable Optical Module Global Configuration
                           ddm-monitor : disabled
                  ddm-monitor-interval : 5
                        ddm-traps-send : enabled
                    ddm-alarm-portdown : disabled
            The following example includes Extreme extended diagnostic information. Not all parts support this information. A value of 254 indicates the part has not been initialized.
Switch:1#show pluggable-optical-modules detail 1/29
                      Pluggable Optical Module Info 1/29 Detail
Port: 1/29
Type: 40GbSR4
DDM Supported : TRUE
Vendor Name  : EXTREME NETWORKS     Partnumber : EQPT404SR4VCM100
Vendor REV   : A                    Vendor SN  : 18260006CNFN01
Vendor Date  : 06/26/18
Wavelength   : 850.00 nm
Digital Diagnostic Interface Supported
Optics Status           : Ok
Calibration             : Internal
RX Power Measurement    : Average
Auxiliary 1 Monitoring  : Not Implemented
Auxiliary 2 Monitoring  : Not Implemented
              LOW_ALARM LOW_WARN    ACTUAL  HIGH_WARN HIGH_ALARM THRESHOLD
              THRESHOLD THRESHOLD   VALUE   THRESHOLD THRESHOLD  STATUS
Temp(C)         -5.0       0.0      31.3710   70.0      75.0     Normal
Voltage(V)       2.9700    3.1000    3.2996    3.4650    3.6300  Normal
Tx1Bias(mA)      2.0       3.0       7.6800   13.0      14.0     Normal
Tx2Bias(mA)      2.0       3.0       7.5520   13.0      14.0     Normal
Tx3Bias(mA)      2.0       3.0       7.6800   13.0      14.0     Normal
Tx4Bias(mA)      2.0       3.0       7.4240   13.0      14.0     Normal
Tx1Power(dBm)  -11.3000   -7.3000   -2.6000    0.0       3.0     Normal
Tx2Power(dBm)  -11.3000   -7.3000   -2.5000    0.0       3.0     Normal
Tx3Power(dBm)  -11.3000   -7.3000   -2.9000    0.0       3.0     Normal
Tx4Power(dBm)  -11.3000   -7.3000   -2.7000    0.0       3.0     Normal
Rx1Power(dBm)  -13.9000   -9.9000   -4.1000    0.0       3.0     Normal
Rx2Power(dBm)  -13.9000   -9.9000   -3.4000    0.0       3.0     Normal
Rx3Power(dBm)  -13.9000   -9.9000   -2.9000    0.0       3.0     Normal
Rx4Power(dBm)  -13.9000   -9.9000   -3.2000    0.0       3.0     Normal
Extreme Extended Diagnostic Information
Power On Counter (48 hours)   : 5
Tx1 DDM Initial (dBm)         : 7
Tx1 DDM Last Gasp (dBm)       : 7
Tx2 DDM Initial (dBm)         : 7
Tx2 DDM Last Gasp (dBm)       : 7
Tx3 DDM Initial (dBm)         : 7
Tx3 DDM Last Gasp (dBm)       : 7
Tx4 DDM Initial (dBm)         : 6
Tx4 DDM Last Gasp (dBm)       : 6
Rx1 DDM Initial (dBm)         : 254
Rx1 DDM Last Gasp (dBm)       : 254
Rx2 DDM Initial (dBm)         : 254
Rx2 DDM Last Gasp (dBm)       : 254
Rx3 DDM Initial (dBm)         : 254
Rx3 DDM Last Gasp (dBm)       : 254
Rx4 DDM Initial (dBm)         : 254
Rx4 DDM Last Gasp (dBm)       : 254
Use the data in the following table to use the show pluggable-optical-modules basic and show pluggable-optical-modules detail commands.
| Variable | Value |
| {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]} | Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
