Import information from other areas to learn their OSPF relationships. Perform this procedure to create normal, stubby, or not-so-stubby areas (NSSA).
  • Ensure that the VLAN exists if you configure OSPF on a VLAN.
  • You configure OSPF on a VRF instance the same way you configure the GlobalRouter, except that you must use VRF Router Configuration mode and the prefix ip ospf. The VRF must have an RP Trigger of OSPF. Not all parameters are configurable on non0 VRFs.
Place stubby or NSSAs at the edge of an OSPF routing domain. Ensure that you configure all routers in a stubby or NSSA as stubby or NSSA, respectively.
  1. Enter OSPF Router Configuration mode:
    enable
    configure terminal
    router ospf
  2. Create an OSPF area:
    area {A.B.C.D}
  3. Specify the area type:
    area {A.B.C.D} import <external|noexternal|nssa>
  4. Configure other OSPF area parameters as required.
  5. Ensure that the configuration is correct:
    show ip ospf area [vrf WORD<1-16>] [vrfids WORD<0-255>]
Create the OSPF area 192.0.2.10, and specify the area type as NSSA. Configure the area support to import summary advertisements into a stub area and configure the import extral option fo this area as stub. Ensure the configuration is correct.
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#router ospf
Switch:1(config-ospf)#area 192.0.2.10
Switch:1(config-ospf)#area 192.0.2.10 import nssa
Switch:1(config-ospf)#area 192.0.2.10 import stub
Switch:1(config-ospf)#area 192.0.2.10 import-summaries enable
Switch:1(config-ospf)#show ip ospf area
                            OSPF Area - GlobalRouter
AREA_ID         STUB_AREA  NSSA          IMPORT_SUM ACTIVE_IFCNT
192.0.2.10      true       false         true       2
STUB_COST INTRA_AREA_SPF_RUNS  BDR_RTR_CNT ASBDR_RTR_CNT LSA_CNT   LSACK_SUM
0         8                    0           0             6         126180
The following table defines parameters for the area {A.B.C.D} command.
Variable
Value
default-cost <0-16777215>
Specifies the stub area default metric for this stub area, which is the cost from 0–16777215. This metric value applies at the indicated type of service.
Specifies the type of area:
  • external—stub and NSSA are both false
  • noexternal—configures the area as stub area.
  • nssa—configures the area as NSSA.
Configures the area support to import summary advertisements into a stub area. Use this variable only if the area is a stub area.
stub
Configures the import external option for this area as stub. A stub area has only one exit point (router interface) from the area.
The following table defines parameters for the show ip ospf area command.
Variable
Value
vrf WORD<1-16>
Specifies a VRF.
vrfids WORD<0-512>
Specifies a range of VRF IDs.
