Perform this procedure to view inventory attributes for LLDP-MED on specific ports.
- Click Port MED.
- Click the Neighbor Inventory tab.
Neighbor Inventory Field Descriptions
Name |
Description |
TimeMark |
Specifies the time filter. For more information about TimeFilter, see the TimeFilter textual convention in IETF RFC 2021. |
LocalPortNum |
Specifies the port on which the remote LLDP-MED information is received. |
Index |
Specifies the particular connection instance that is unique to the remote LLDP-MED. |
HardwareRev |
Specifies the current hardware revision of the LLDP-MED. |
FirmwareRev |
Specifies the current firmware revision of the LLDP-MED. |
SoftwareRev |
Specifies the current software revision of the LLDP-MED. |
SerialNum |
Specifies the current serial number of the LLDP-MED. |
MfgName |
Specifies the manufacturer of the LLDP-MED. |
ModelName |
Specifies the model name of the LLDP-MED. |
AssetID |
Specifies the asset tracking identifier for the LLDP-MED. |
