Perform the following procedure to view the number of remaining virtual services resources on the switch.
- Click Virtual Service.
- Click the Globals tab.
Use data in the following table to use the Globals tab.
Name |
Description |
DiskRemain |
Shows the remaining disk space available, in Gigabytes (GB). |
NumCoresRemain |
Shows the remaining number of CPU cores available. |
MemSizeRemain |
Shows the remaining amount of memory size available, in Megabytes (MB). |
