View PIM-SM neighbor parameters to troubleshoot connection problems or review the configuration.
- In the navigation pane, expand the following folders: .
- Click PIM.
- Click the Neighbors tab.
Neighbors field descriptions
Use the descriptions in the following table to use the Neighbors tab.
| Name | Description |
| Address | Shows the IP address of the PIM neighbor. |
| IfIndex | Shows the slot and port number or VLAN ID of the interface used to reach this PIM neighbor. |
| UpTime | Shows the time since this neighbor became a neighbor of the local router. |
| ExpiryTime | Shows the time remaining before the neighbor expires. |
