View VRFs corresponding to Layer 3 (routed) VSN I-SIDs on either a Controller or a Leaf node.
Ensure that you enable DvR globally on the node.
L3–VSN field descriptions
Use the data in the following table to use the L3–VSN tab.
| Name | Description |
| VrfId | Specifies the VRF ID of the VRF corresponding to the Layer 3 VSN I-SID. |
| Isid | Specifies the Layer 3 VSN I-SID. |
| VrfName | Specifies the VRF name of the VRF corresponding to the Layer 3 VSN I-SID. |
| InjectDefaultRouteDisable | Specifies whether injection of default routes is disabled. |
