To use the console port, you need the following equipment:
A terminal or TeleTypewriter (TTY)-compatible terminal, or a portable computer with a serial port and terminal-emulation software.
A specific cable with an RJ–45 or USB connector for the console port on the switch. The other end of the cable must use a connector appropriate to the serial port on the computer or terminal.
To comply with emissions regulations and requirements, you must shield the cable that connects to the console port.
If you are using the VSP 4900 Series, 5420 Series, or 5520 Series USB console port with a terminal running Windows 10, you must install the CP210x USB to UART Bridge Virtual COM Port (VCP) driver from Silicon Labs before you connect to the terminal.
Connect a terminal to the serial console interface to monitor and configure the system directly.
9600 baud or 115200 baud, depending on the hardware platform.
8 data bits
1 stop bit
No parity
No flow control
