Perform this procedure to display the port shortcut menu.
- In the Device Physical View, select a port.
- Right-click the selected port.
Port shortcut menu field descriptions
Use the data in the following table to use the port shortcut menu.
Name |
Description |
Edit General |
Configures the general options for the port. |
Edit IP |
Configures the IP options for the port. |
Edit IPv6 |
Configures the IPv6 options for the port. |
Channelization Enable |
Enables channelization for the port. |
Channelization Disable |
Disables channelization for the port. |
Graph |
Displays the statistics for the port. |
Enable |
Enables the port. |
Disable |
Disables the port. |
