Add a remote NTP server to the configuration by first specifying its IP address. NTP adds this IP address to a list of servers, which the local NTP client uses to query remote time servers for time information. The list of qualified servers called to is a peer list.
For NTPv4, this procedure adds the NTP server information to the switch that is acting as an NTP client. You can configure a maximum of 10 IPv4 NTP servers and 10 IPv6 NTP servers.
- Click NTPv4.
- Click the Server tab.
- Click Insert.
- Specify if the IP address is IPv4 or IPv6.
- Specify the IP address of the NTP server.
- Click Insert.
Server field descriptions
Use the data in the following table to use the Server tab.
Name |
Description |
ServerAddressType |
Specifies the address type as IPv4 or IPv6. |
ServerAddress |
Specifies the IP address of the remote NTP server. |
Enable |
Activates or disables the remote NTP server. The default is enabled. |
Authentication |
Activates or disables MD5 or SHA1 authentication on this NTP server. MD5 or SHA1 produces a message digest of the key. MD5 or SHA1 verifies the integrity of the communication, authenticates the origin, and checks for timeliness. The default is no authentication. |
KeyId |
Specifies the key ID used to generate the MD5 or SHA1 digest for this NTP server. The default is 0, which indicates that authentication is disabled. |
Stratum |
Shows the stratum of the server. |
Version |
Shows the NTP version of the server. |
Broadcast |
Shows if broadcast is enabled or disabled |
AuthEnabled |
Shows if authentication is enabled or disabled |
AuthStatus |
Shows the authentication status. |
Synchronized |
Shows the status of synchronization with the server. |
Reachable |
Shows the NTP reachability status of the server. |
RootDelay |
Shows the root delay of the server. |
RootDisp |
Shows the root dispersion of the server. |
ServerDelay |
Shows the delay of the server. |
Dispersion |
Shows the dispersion of the server. |
Offset |
Shows the offset of the server. |
Precision |
Shows the NTP precision of the server in seconds. |
Jitter |
Shows the jitter of the server |
LastEvent |
Shows the last event of the server. |
