This procedure only applies to VSP 8400 Series.
The following example displays MACsec MKA statistics for a port.
Switch:1>show macsec mka statistics 3/5
MKPDU Statistics on interface 3/5
MKPDUs Validated & Rx : 1630
Rx Distributed SAK : 2
MKPDUs Transmitted : 1694
Tx Distributed SAK : 0
Use the data in the following table to use the show macsec mka statistics command.
| Variable | Value |
| {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]} |
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
