Use the following procedure to configure SPBM on an interface.
- Click IS-IS.
- Click the Interfaces tab.
- Click the SPBM button.
- In the Interfaces SPBM tab, click Insert.
- Click Insert.
SPBM field descriptions
Use the data in the following table to use the Interfaces SPBM tab.
Name |
Description |
Index |
Specifies an Index value for the SPBM interface. |
SpbmId |
Specifies the SPBM ID. |
State |
Specifies whether the SPBM interface is enabled or disabled. |
Type |
Configures the SPBM instance interface-type on the IS-IS interface located on the specified port or MLT: ptpt or bcast. Only the point-to-point (ptpt) interface type is supported. |
L1Metric |
Configures the IS-IS Interface level 1 metric on the specified port or MLT. The default value is 10. |
| Origin Note:
Exception: not supported on VSP 8600 Series and XA1400 Series. |
Specifies the source of the SPBM instance configuration, either manually configured through CLI or EDM or dynamically configured through Auto-sense. |
