You must configure a RADIUS server before you can enable RADIUS accounting.
Enable Remote Access Dial-in User Services (RADIUS) accounting to log all of the activity of each remote user in a session on the centralized RADIUS accounting server.
Switch:1> enable
Switch:1# configure terminal
Switch:1(config)# radius accounting enable
Switch:1(config)# radius accounting include-cli-commands
The following table defines parameters for the radius accounting command.
Variable |
Value |
enable |
Enable RADIUS globally. |
include-cli-commands |
Include CLI commands in RADIUS accounting updates. |
attribute-value <192–240> |
Specify the integer value of the CLI commands attribute. |
