Change a specified RADIUS server value without having to delete the server and recreate it again.
RADIUS supports IPv4 and IPv6 addresses, with no difference in functionality or configuration using CLI.
Modify a RADIUS server:
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#radius server host 4717:0000:0000:0000:0000:0000:7933:0001 used-by snmp port 12 retry 5 timeout 10 enable
The following table defines parameters for the radius server host command.
Variable |
Value |
used-by {cli|eapol|endpoint-tracking|snmp|web} |
Configures how the server functions:
Use the no option to remove a host server: no radius server host WORD<0–46> used-by {cli|eapol|endpoint-tracking|snmp|web}. The default is cli. The default command is: default radius server host WORD<0–46> used-by {cli|eapol|endpoint-tracking|snmp|web}. |
host WORD <0–46> |
Configures a host server. WORD <0–46> signifies an IPv4 address in the format A.B.C.D or an IPv6 address in the format x:x:x:x:x:x:x:x. RADIUS supports IPv4 and IPv6 addresses, with no difference in functionality or configuration using CLI. |
acct-enable |
Enables RADIUS accounting on this server. The system enables RADIUS accounting by default. |
acct-port <1-65536> |
Configures the UDP port of the RADIUS accounting server (1 to 65536).
The default value is 1813.
Important:
The UDP port value set for the client must match the UDP value set for the RADIUS server. |
enable |
Enables the RADIUS server. The default is true. |
key WORD<0–32> |
Configures the secret key of the authentication client. |
port <1-65536> |
Configures the UDP port of the RADIUS authentication server. The default value is 1812. |
priority <1–10> |
Configures the priority value for this server. The default is 10. |
retry <0–6> |
Configures the number of authentication retries the server will accept. The default is 3. |
secure-enable Note:
Exception: not supported on VSP 8600 Series. |
Enable RADIUS Security (RADSec). |
secure-log-level Note:
Specifies the log severity level. Possible values are :
secure-mode Note:
Specifies the protocol used for secure connection to the server. |
secure-profile Note:
Configures the secure profile for the server. |
source-ip
WORD
<0–46>
Note:
Exception: only supported on VSP 8600 Series. |
Configures an IP address as the source address when transmitting RADIUS packets. To use this option, you must have the global RADIUS sourceip-flag set to true. RADIUS supports IPv4 and IPv6 addresses, with no difference in functionality or configuration using CLI. |
timeout <1–180> |
Configures the number of seconds before the authentication request times out. The default is 8. |
