Viewing VRRP Statistics
View VRRP statistics to monitor network performance.
- Click VRRP.
- Select the Stats tab.
Stats Field Descriptions
The following table describes parameters on the VRRP statistics tab.
Name |
Description |
ChecksumErrors |
Specifies the number of VRRP packets received with an invalid VRRP checksum value. |
VersionErrors |
Specifies the number of VRRP packets received with an unknown or unsupported version number. |
VrIDErrors |
Specifies the number of VRRP packets received with an invalid VrID for this virtual router. |
