Configure the serial port devices to define connection settings for the console port. Depending on your hardware platform the console port displays as console or 10101.
These commands do not apply on all hardware platforms.
Switch:1>enable Switch:1#config terminal Switch:1(config)#show boot config sio sio console baud 115200 2 sio console baud 115200 5 sio console baud 115200 8 sio console baud 115200 SF1 sio console baud 115200 SF3
Configure the baud rate to 9600 for the console port in IOC module slot 2:
Switch:1(config)#boot config sio console baud 9600 2 Switch:1(config)#show boot config sio sio console baud 9600 2 sio console baud 115200 5 sio console baud 115200 8 sio console baud 115200 SF1 sio console baud 115200 SF3
The following table defines parameters for the boot config sio console command.
Variable |
Value |
baud <9600–115200> |
Configures the baud rate for the port from one of the following:
The default value differs depending on hardware platform:
<1–8> | <SF1–SF3> Note:
Exception: only supported on VSP 8600 Series. |
Configures the individual console baud rate for the IOC modules in slots 1 through 8 or the switch fabric (SF) modules in slots SF1 through SF3. |
