Perform this procedure to display the parameters configured currently on the Fabric IPsec Gateway Virtual Machine (VM).
enable
virtual-service WORD<1-128> console
Type CTRL+Y to exit the console.
show running-config
Switch:1> enable Switch:1# virtual-service figw console Connected to domain figw Escape character is ^Y <cr> FIGW> show running-config set global ipsec-tunnel-src-vlan 125 set global ipsec-tunnel-src-ip 192.0.2.1/24 set global lan-intf-vlan 30 set global lan-intf-ip 192.0.2.10/24 set global lan-intf-gw-ip 192.0.2.25 set global fe-tunnel-src-ip 192.0.2.55 set global wan-intf-gw-ip 192.0.2.11 set global mtu 1950 set ipsec 1 auth-key ****** set ipsec 1 fe-tunnel-dest-ip 192.0.2.70 set ipsec 1 encryption-key-length 128 set ipsec 1 admin-state enable
