Display information about BGP network configurations.
The following table defines parameters for the show ip bgp networks command.
Variable |
Value |
<prefix/len> |
Shows paths with this prefix. The prefix is the IP address and exact mask length (must be an integer value from 0–32). |
vrf WORD<1–16> |
Specifies a VRF instance by name (the string length ranges from 1–16 characters). |
vrfids WORD<0–512> |
Specifies a range of VRFs by ID number (the ID ranges from 0–512). |
