This procedure only applies to the VSP 7400 Series.
Perform this procedure to view the remote link-state packet (LSP) summary information. Link State Packets (LSP) contain information about the state of adjacencies or defined and distributed static routes. Intermediate-System-to-Intermediate-System (IS-IS) exchanges this information with neighboring IS-IS routers at periodic intervals.
- Select IS-IS Remote.
- Select the LSP Summary tab.
LSP Summary Field Descriptions
Use the data in the following table to use the LSP Summary tab.
Name |
Description |
Level |
Specifies the level at which the system displays the remote LSP. |
ID |
Specifies the 8-byte LSP ID, consisting of the system ID, circuit ID, and Fragment Number. |
Seq |
Specifies the sequence number for the LSP. |
Checksum |
Specifies the 16-bit Fletcher Checksum for the LSP. |
LifetimeRemain |
Specifies the remaining lifetime in seconds for the LSP. |
HostName |
Specifies the host name. |
