Use this procedure to configure the source of the Application Telemetry packets.
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#sflow agent-ip 192.0.2.27
Use the data in the following table to use the sflow agent-ip command.
Variable |
Definition |
{A.B.C.D.} |
Specifies the agent-ip address (IPv4). |
