Clear KHI statistics.
- In the Device Physical View tab, select the Device.
- Click Chassis.
- Click the CPP Stats Control tab.
- Select the statistics you want to clear.
- Click Apply.
CPP Stats Control Field Descriptions
Use the data in the following table to use the CPP Stats Control tab.
Name |
Description |
PortStatsClear |
Clears port statistics. |
