Configuring CFM MD
Use this procedure to configure the Connectivity Fault Management (CFM) Maintenance Domain (MD). An MD is the part of a network that is controlled by a single administrator. A single MD can contain several Maintenance Associations (MA).
Switch:1> enable
Switch:1# configure terminal
Switch:1(config)# cfm maintenance-domain md1 index 99 maintenance-level 3
Switch:1(config)# show cfm maintenance-domain
Maintenance Domain
Domain Name Domain Index Level Domain Type
md1 99 3 NODAL
Total number of Maintenance Domain entries: 1.
Switch:1(config)# no cfm maintenance-domain md1
Maintenance Domain
Total number of Maintenance Domain entries: 0.
The following table defines parameters for the cfm maintenance-domain command.
Variable |
Value |
WORD<0–22> |
Specifies the maintenance domain name. |
index <1–2147483647> |
Specifies a maintenance domain entry index. |
maintenance-level <0–7> |
Specifies the MD maintenance level when creating the MD. The default is 4. |
level <0–7> |
Modifies the MD maintenance level for an existing MD. The default is 4. |
