View the DvR routes (IPv4 network routes) on a DvR Controller or a Leaf node.
Controllers display all the IP subnet routes configured for that DvR domain. The Leaf nodes display the IP subnet routes that are learned from the Controller(s) for the Layer 2 VSNs in the DvR Domain. Leaf nodes also display routes that are redistributed by Controllers (direct routes, static routes and the default route), into the DvR domain.
Ensure that you enable DvR globally on the node.
View DvR routes on either a Controller or a Leaf node.
Viewing the DvR routes for a specific VRF or VRF ID is not supported on a DvR Leaf node.
Switch:1#show dvr routes
DVR Routes
NEXT L3VSN L2VSN
DEST MASK HOP VRFID ISID ISID TYPE COST
50.0.0.0 255.255.0.0 Ctrl-1:8400:121 0 55500 50500 - 1
1 out of 1 Total Num of DVR Routes displayed
TYPE Legend: E=Ecmp Route
View DvR routes where the next hop MAC address is displayed instead of the system name:
Switch:1#show dvr routes nh-as-mac
DVR Routes
NEXT L3VSN L2VSN
50.0.0.0 255.255.0.0 00:bb:00:00:01:02 0 55500 50500 - 1
Variable definitions
Use the data in the following table to use the show dvr routes command.
Variable |
Value |
ipv4 {A.B.C.D} |
Specifies the IP address (IPv4) of the DvR route. |
l3isid <0-16777215> |
Specifies the Layer 3 I-SID of the DvR route. The range is 0 to 16777215. |
nh-as-mac |
Specifies the MAC address of the next hop node instead of the system name. |
vrf |
Specifies the VRF name of the DvR route. |
vrfids |
Specifies the VRF ID of the DvR route. The range is 0 to 512. |
