View the VLAN port member status to display the port member status for all VLANs on the device or for the specified VLAN.
View VLAN port member status:
Switch:1> show vlan members port 1/2
Vlan Port
VLAN PORT ACTIVE STATIC NOT_ALLOW
ID MEMBER MEMBER MEMBER MEMBER
2 1/2,1/5-1/8,1/11, 1/2,1/5-1/8,1/11,
1/14,1/26,1/38 1/14,1/26,1/38
3 1/2,1/5-1/8,1/14, 1/2,1/5-1/8,1/14,
1/26,1/38 1/26,1/38
4 1/1-1/2,1/5-1/8, 1/1-1/2,1/5-1/8,
1/13-1/14,1/25- 1/13-1/14,1/25-
1/26,1/37-1/38 1/26,1/37-1/38
100 1/2,1/14,1/23- 1/2,1/14,1/23-
1/24,1/26-1/28, 1/24,1/26-1/28,
1/38 1/38
300 1/2,1/5-1/8,1/14, 1/2,1/5-1/8,1/14,
1/26,1/38 1/26,1/38
Variable definitions
Use the data in the following table to use optional parameters with the show vlan members command.
Variable |
Value |
null-vlan |
Displays port members of the NULL VLAN. This is a place holder VLAN for ports that are not members of any port-based VLAN. When a port is removed from all port-based VLANs, it is added to the NULL VLAN as a port member. The NULL VLAN is an internal construct and cannot be deleted. |
{slot/port[/sub-port][-slot/port[/sub-port]][,...]} |
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. If you do not specify a port, the command shows information for all the ports. |
<1-4059> |
Specifies the VLAN ID in the range of 1 to 4059. By default, VLAN IDs 1 to 4059 are configurable and the system reserves VLAN IDs 4060 to 4094 for internal use. On switches that support the vrf-scaling and spbm-config-mode boot configuration flags, if you enable these flags, the system also reserves VLAN IDs 3500 to 3998. VLAN ID 1 is the default VLAN and you cannot create or delete VLAN ID 1. Note:
Entering a VLAN ID is optional. If you enter a VLAN ID the command shows information for the specified VLAN or port. Without the VLAN ID the command shows information for all the configured VLANs. |
