Copy files on the internal flash.
- Click File System.
- Click the Copy File tab.
- Edit the fields as required.
- Click Apply.
Copy File Field Descriptions
Use the data in the following table to use the Copy File tab.
Name |
Description |
Source |
Identifies the device and file name to copy. You must specify the full path and filename, for example, <deviceip-ftp server>:/<filename> |
Destination |
Identifies the location to which to copy the source file with the filename, for example, /intflash/<filename> |
Action |
Starts or stops the copy process. |
Result |
Specifies the result of the copy process:
