Create an IP VPN instance to advertise IP routes from one VRF to another across a Shortest Path Bridging MAC (SPBM) network.
You must configure the required SPBM IS-IS infrastructure.
The VRF must exist.
VPN Field Descriptions
Use the data in the following table to use the VPN tab.
 Name  |
 Description  |
 VrfId  |
 Specifies the ID of the VRF to configure.  |
 Enable  |
 Enables or disables the IP VPN instance on the VRF. The default is disabled.  |
 Isid Number  |
 Specifies the I-SID to associate with the VPN. By default, no I-SID is assigned.  |
                                 Isid Name Note:
                            This field does not apply to all hardware platforms.  |
                                 Specifies the name of the I-SID associated with the VPN.  |
